Having trouble getting the rear bumper aligned properly. 2 problems; the forward tip of each end of the bumper is 3/4" on the left side and 1/2" on the right side from meeting the attachment hole in the side of each rear fender, the manual calls for a rubber shim from 1/8" to 1/4 inch, but that falls far short of "filling" in the gap. Is this typical; how far should the tip of the bumper be from the fender and is the fender flexible enough to be pulled out toward the bumper tip? After nearly 6 weeks of paint and color sanding I do not want to crack the fender.? The second problem is the distance from the top edge of bumper varies from the back of the car body by nearly 3/4 inch from left to right on a horizontal plain along the top edge of the bumper. I can't see how this is adjusted without elongating the bumper brackets that are attached to the frame. see the pics. Ken Deltaville, Va
added 4-24 --THANKS for help, both issues have be resolved. The gap on each side is now equal by reworking the horizontal slots in the main support frame and the bumper is now even across the back of car; this was done by elongating the holes in the left side suppot bracket where it is bolted to the car frame thus allowing the bumper to be pulled forward on the left side. Thanks agian, Ken
