Alright, so the engine seemed to run alright, besides the crack in the carb and the oil leak from the rear main. So we finally decided to rip out the motor to do the main seal. We take the engine out, without too much trouble, just getting the tranny stuck on the dowels, but nothing major there.
I figured since we had the motor out, Id give it a good cleaning and I would paint the block so I started scrubbing, everything was caked on with oil (from a previously huge leak on both the rocker covers). I start to clean on around the freeze of plugs and notice one of them is indented very far in, but didn't seem to be cracked or leaky.
Figured I'd just knock it out and replace it since I didn't like that way that it looked....this is what I found when i removed the plug....
The previous owner told me that it sat for a few years and no one moved it before... I drove it around a few times and it never overheated.... I did flush out the radiator 2 times, but after running it for a while it was coming back up brown anyways. Even after just running the hose thru it for like 30 minutes.
Is this from the antifreeze?
When ever I saw old antifreeze it was always like brown, and this is black. Has some brown in it too when you dig deeper in there... but I don't know. I dug out as much as I could with a flat screwdriver but there is a ton more.... and I haven't even gotten to the water pump yet.
Figured I'd also take the valley cover off the in process and see how that looks and found this stuff
First I just thought it was oil, but when i tried to remove it, it was all gooey like clay or something.
No clue what that is, hope someone has an idea....
