OK, now that I finally fought one of the original front mounts out ('57 Golden Hawk), it is time to put the new Classic body support mount in.
Looking things over and recalling how they came apart, I have two questions:
1) the original support had three bolts through it: the Classic piece has TWO bolt holes (both inboard). No problem drilling a hole in the outboard area for a bolt, but it occurred to me that I had the luxury of breaking that bolt off while I had the floor cut out. :-) (You can just see the raised "mound" of the remains of a nut on the outboard end of the original in the attached photo) So, I assume I'll need to weld a nut to the Classic piece in the same location as the original rusted-out nut was.... There appears to be quite a bit of room in the batwing hole to allow adjustment later, so should be ok 'getting close" with the drilled hole and welded nut"? Don't have to have the whole thing 'assembled" and in place and floor tacked in, etc... before doing so? Which leads me to question #2:
2) finally occurred to me (this is my first time at this, forgive me) that the new floor piece is going to have to go in and at least get screwed down for "final fit" before I can finalize the position of the new Classic body support arm... because the FLOOR is between the cowl pillar and the end of the body support. So I can't weld the support arm to the cowl pillar (and the new floor) until it is ALL final.
I suppose I CAN spot-weld the torque boxes to the body support arm, then put the new floor on, assuming I can slip the floor between the pillar and raised outboard end of the body support arm.
This whole thing is all interlinked and intertwined, much more so than I had imagined! Even the torque boxes had one on top, the other on the bottom, making the hunt for spot welds oh so much fun! :-) Here is the "rejected" and "ejected" mount this afternoon, and the now-vacant torque boxes:
