That's...."Word To The Wise...
Those of you doing your own porting...
I thought I'd check the common wall thickness (exh. to int.) before "rounding" off that part of the intake bowl wall. This is with using either the stock 1.750" dia valve and espicially the R3, 1.875" dia. valve.
On one pair I'm now reworking, I found "one" intake port that was very thin (as checked SEVERAL times with my sonic checker). And that was with NO grinding yet. I even lightly smoothed the wall to get rid of any roughness, at least on the port side. No help..!
I was told (by a pro) about .095" to .100" was about as thin a wall as you'd want to go.
Well, this one port was already only .180" thick to start with. .080" isn't nearly enough to fully "round" the bowl of the port.
All the rest of the ports are .220" to .240" thick at the common wall...which is about enough to round off the bowl..and leave suffecient wall thickness.
Was this caused by rust, casting porosity, a bad casting plug....no clue....but I've already got enough money into these heads to NOT take the chance and loosing a head. I'm not Pro Stock racing....so...I'd rather loose a coupla CFM than a head.
And just to drive this home a little more, one of the high dollar (moved the valve over) sets I'm reworking, was also thinner than I'd like....and this was with moving the valve over..."away" from the exhaust..!
While not as pretty...might be a good idea to leave that part of the intake bowl a little flat..!
As someone around here always says...your heads, your money..do as you see fit.
I thought I'd just pass along the information I found this morning.
