I ordered an aluminum 3-row radiator for a 72-86 Jeep V8 CJ ($185 on eBay!!! http://cgi.ebay.com/ebaymotors/72-86...ht_2795wt_1123 ) and I'm thinking I should get a fan shroud for it as well - does anybody know offhand if the stock CJ fan shroud fits with a Stude clutch fan? Can't seem to find the dimensions anywhere on line. I assume it will mount up ok just wondering about depth and fan opening size.
Aluminum Radiator conversion
Tags: None
Proud NON-CASO
Romans 15:13
Deuteronomy 31:6
Proverbs 28:1
Illegitimi non carborundum
That radiator looks perfect for my Chevy conversion on my 62 Lark. The EBay listing says it includes an internal trans cooler. I will be running a Muncie 4 speed, so won't need that, but was wondering if the same internal cooler could be used for an oil cooler instead?
The CJ fan shroud has notches for the hoses in different locations and the opening is not centered for the fan. You normally need to really cut one up to get it to fit and by that time it looks terrible! As for the trans cooler in the alum. radiator to be used for an engine oil cooler - I would not do this as it would restrict flow! These are normally 5/16" lines and most oil cooler lines are 1/2". Big difference in flow capabilities.1958 Transtar 3E6-122
1958 Transtar 3E13-31
1959 Transtar 4E7-122
1959 Lark 2 door Wagon
1960 Transtar 5E28-171
1960 Lark Gasser
1963 Daytona
Pat, when you get your radiator installed can you please put up some pic's of the install and any modifications that you had to do.
I am thinking of doing the same on a project.
Thanks,George King
Grants Pass, Oregon
64 Station Wagon with fixed roof (Canadian Car)
66 Station Wagon with fixed roof. Project car, complete For Sale...
64 Wagonaire sliding roof South Bend car. For Sale...
63 GT Hawk
51 Champion Starlight Coupe For Sale...
Originally posted by Orestudeguy View PostPat, when you get your radiator installed can you please put up some pic's of the install and any modifications that you had to do.
Thanks,
That said, if normal operating temp for s Stude is 180 - 200 degrees as some have said, why is the middle of the temp gage about 160? What kind of bonehead engineer designs something that way?
Originally posted by pdrnec View PostThat said, if normal operating temp for s Stude is 180 - 200 degrees as some have said, why is the middle of the temp gage about 160? What kind of bonehead engineer designs something that way?Proud NON-CASO
Romans 15:13
Deuteronomy 31:6
Proverbs 28:1
Any chance that a 'regular' replacement radiator for a 1972-86 Jeep CJ would work in lieu of the aluminum unit?--------------------------------------
