So, you wanna mount a trunk mounted battery. Future Modifications are going to require real estate(in my case I'm looking at a couple of exhaust driven compressors up there), and you need to move the battery but retain the starting capabilities. Well, you could use a stock 12 volt cable, but long thin cables compared to their stock counterparts can make for increased resistance in the wire. According to the properties of electricity in a wire, ideally, we need something as short and fat as possible. You can use welding cable which is never a bad idea, but if you have a Farm and Fleet with a healthy Agricultural section, you can also get 25' of 2 Gauge wire on a spool for 40 bucks, like I did, if welding cable is unavailable [)]. This also came in spools of 4 and 6 gauge and in lower length quantity.
Don't forget your matching 2 gauge terminals and connectors as well
This will also help those of you with that troublesome six volt situation, but in this case it will provide you with a lifetime supply if you get the big roll [)]. I'll quit the wiseguy act now, lol...
[IMG=left]http://i158.photobucket.com/albums/t102/PlainBrownR2/55%20Studebaker%20Commander%20Streetrod%20Project/P1010531-1.jpg[/IMG=left]
[IMG=left]http://i158.photobucket.com/albums/t102/PlainBrownR2/55%20Studebaker%20Commander%20Streetrod%20Project/P1010550-1.jpg[/IMG=left]
[IMG=right]http://i158.photobucket.com/albums/t102/PlainBrownR2/Ex%20Studebaker%20Plant%20Locomotive/P1000578-1.jpg[/IMG=right]
[IMG=right]http://i158.photobucket.com/albums/t102/PlainBrownR2/My%201964%20Studebaker%20Commander%20R2/P1010168.jpg[/IMG=right]
