Window stops
  • Body / Glass: Window stops
    '61 Hawk door windows. How do I adjust the stop for the window down.? It goes below the "cat wiskers" when rolling down. - Jim
    If you don't have the shop books..... you will find by trail & error a nut & bolt that holds a rubber stop usually in the bottom of the center regulator opening in the door. Obviously, you've removed the inside door panel.
      Here is a picture of the stop on the Golden Hawk. I assume yours will be the same.
        That's it! I asked about that clip a while ago, but, the answer wasn't clear. Now that I see it, I know it's not something somebody stuck in there for ???. Thanks. Jim
