Window aftermarket seal
Tags: None
The cat whiskers were never intended to stop water. What they do is protect the door cavity from large pieces of dirt/trash, keep the windows from rattling, and, most of all, prevent the windows from contacting the metal contact which is a sure way to get them broken. If your doors are filling up with water, that means your door drains are clogged up. You can clear them with an old dull hacksaw blade or similar item of your choice.
Several of the Studebaker parts vendors can sell you new catwhisker material for you to cut and replace your worn out old ones. Be patient, and I'm sure that someone will post a resource link. Happy to have you here, welcome to our forum.John Clary
Hey Hugh, I just now came back into the house to take a break from chores. I noticed that no one has posted a link yet to a vendor offering what you need. Here's one... http://www.studebakervendors.com/hansen/index.htm
I hope this will be useful for you.John Clary
If the "cat whiskers" have been kaput for any length of time and the drain holes have clogged up I suggest you remove the door panel and do a thorough cleanout. The bottom of your door is probably full of dirt, leaves, and all sorts of nasty gunk. If allowed to stay there is a good chance the door bottom will rust.
I'll bet your Australian vendors can supply cat whiskers also.Don Wilson, Centralia, WA
40 Champion 4 door*
50 Champion 2 door*
53 Commander K Auto*
53 Commander K overdrive*
55 President Speedster
62 GT 4Speed*
63 Avanti R1*
64 Champ 1/2 ton
* Formerly owned
Thank guys, I was thinking of stoping the water from going in the door altogether by retro fitting a seal off another car still utilising the inside whisker. Might have to experiment with something from the wreckers. Yes Chris very helpful.
Thanks again
Originally posted by hughbe View PostThank guys, I was thinking of stoping the water from going in the door altogether by retro fitting a seal off another car still utilising the inside whisker. Might have to experiment with something from the wreckers. Yes Chris very helpful.
Thanks againSkip Lackie
Bez Auto Alchemy
Update, if any body else is interested i found an aftermarket "flocked window trim drip seal" sold by the meter for ten bucks per meter from car builder solutions which should work perfectly if i can find a way to fix it to the rusty door flange. The seal has a felt surface on the glass side and a small lip that flaps tightly over outer door, with a smal bead of silicon it should stop unwanted water entering.
Originally posted by hughbe View PostUpdate, if any body else is interested i found an aftermarket "flocked window trim drip seal" sold by the meter for ten bucks per meter from car builder solutions which should work perfectly if i can find a way to fix it to the rusty door flange. The seal has a felt surface on the glass side and a small lip that flaps tightly over outer door, with a smal bead of silicon it should stop unwanted water entering.
Dale
