In rebuilding the 63's OHV six, I'm not planning to reuse the ASB carb that came with it. Instead, I've had good luck with those old WE Carters and it looks like it's a good fit, linkage and all.
This carb appears clean and not too used after a rebuild. (I don't recall how I came into it's possession.) Anyhoo, since I don't know how long it's been sitting around, should I soak that leather piston in oil overnight before resuing the carb? BTW, I opened the plates and looked through the carb for crud & cobwebs but was clean.
An air cleaner might be tricky. This is a taller carb. Thanks!
Western Washington, USA
