Of all of Studebaker's good design features.... the trailing edge of their front fenders...'47 forward was not one of them! Basic existence of the car guaranteed that rust would eventually eat through 2 1/2 inches from the back of the fender, even on Arizona cars.
You old timers can probably make this fix in your sleep and I soon will be able to as well as I have begun the patch panel job on my 3 Studes. I'm glad I am using my Champ as practice before I dive into the Speedster. I'm 2 days into my first fender and have taken lots of notes and pictures. There is a bit more to it than unbolt the fender and slip on the Patch. Since I am learning to weld with a toy welder from Harbor Freight at the same time, you old pro's should get comic relief from my story.
Classic Enterprises supplies a nice clip but the fine print on their instructions indicates that their dimensions are merely approximations and you will need further panel beating to make them fit. They were definitely correct on that count but the critical dimension from the crease to the top of the fender was spot on... curvatures earned the attention of my 5 pound mallet.
I try and avoid saying I will do something because my plans always seem to get changed, but I hope to put my tricks and mistakes learned into a youtube for the benefit of any newbees who have intentions of fixing the problem instead of just adding another layer of bond.
I figure at least on the Champ, I can't cause much damage that can't be cured with a grinder, hammer and a couple of pounds of Bondo !
