While attempting to replace a weeping freeze plug, I inadvertently broke off the lines to the oil filter at the fittings. I viewed several vendor sites and it seemed that flexible hoses were the only options. The one line is over 2 ft long. Just wanted to get some suggestions as to what others may have done. This line may still be salvageable if the fittings are still available. Thank you.
Here is the freeze plug that I was attempting to remove
