I thought that I had done enough research in the difference of these two engines before I decided to try to install the bigger one in my ‘48 M16. I have run into small annoyances like, the motor mounts from where the 246ci came from not working and, the engine mounting plate clocked wrong for my starter. I knew that the water pump was different but, I didn’t anticipate an interference issue. The flange which carries the pulley and fan is too close to the radiator to install the fan or even the fan shroud. The water pump pulleys are not interchangeable, the one off of the 226ci is about an inch too short.
To make up some of the difference, I have thought about pressing the waterpump flange further on the shaft ( it can go about 3/8”) but, if I do, the pulley may not line up. Right now I don’t have the correct pulley for the 246ci so I don’t know if the flange is in the proper location.
Another thing I am concerned about is how close should or can a fan be to the radiator.
Does anyone have the correct pulley for the 246ci they could measure the height and diameter?
Has anyone else run into this engine swap problem?
Thanks, Neal
Thanks, Neal
