I am seeking any advice on replacing the starter motor in my 1937 Dictator. My preference is to find a replacement that will operate effectively on a 12 volt system. Any ideas on what my options are, cost and availability would be greatly appreciated. Thanks.
Replacement starter motor for my 1937 Dictator
I have one from '38 Commander that works; it started the engine when I tried it. The engine is toast, you can see the piston rings past the eroded tops of the pistons, but it ran for a few minutes. I will likely never use it, so the starter is up for grabs. I doubt there is a direct-replacement 12 volt starter out there. Most manufacturers seem to have changed tooth count on their ring gears when they went from six to twelve volts, probably to ensure that starters were not wrongly substituted. But a healthy six-volt starter will last for years, when run on twelve volts, as long as you don't use it to crank a balky engine to the point that the battery goes flat.Gord Richmond, within Weasel range of the Alberta Badlands
