Any special tricks I should know of pitfalls to watch for?
Replacing vent window rubber on a 55 K
Body / Glass: Replacing vent window rubber on a 55 K
Don Wilson, Centralia, WA
40 Champion 4 door*
50 Champion 2 door*
53 Commander K Auto*
53 Commander K overdrive*
55 President Speedster
62 GT 4Speed*
63 Avanti R1*
64 Champ 1/2 ton
* Formerly ownedTags: None
This website is for sale! raylinrestoration.com is your first and best source for all of the information you’re looking for. From general topics to more of what you would expect to find here, raylinrestoration.com has it all. We hope you find what you are searching for!
This is for a coupe but similar
There are good tips in here.
I slit the rubber, on the inside, to the pivot pin hole. That way, it is not necessary to remove the vent window, and only need to work the rubber into place. An old trick Lester Schmidt taught me several decades ago. R.I.P. Les
I too, drill a hole in the door to access the pivot pin adjustment screw, and like to shoot a little silicone spray in there to loosen it up, if its hard to pivot. Otherwise, the pivot pin is more likely to break in the window frame. Its very fragile at that connection anyway, so it helps to be careful.
