I've noticed my original key is stubborn to even gently put in the ignition of my '66 Cruiser, and it's sticky to get out, too. Time for the old graphite trick, or what do you suggest?
Also, I faintly remember that George Hamlin had a minor tech article in an old TW about '63 Lark ignition switches moving around in the bezels where when you push the key in, contact is made behind the switch that could result in a fire. I seem to remember that the later cars (switch on right side) weren't like this, per George, but I remember his suggestion was to put electrical tape behind the switch as a buffer from making contact, metal-on-metal, when the key is inserted into the ignition switch. I did do that on my '63 way back when.
My '66's switch seems to move around a little bit in the bezel, too.
