We are rebuilding the 289 engine in my '62 GT Hawk. What color should the throttle linkage between the accelerator and the carb be?
Throttle Linkage
I just looked a NOS one and would say they were cad-plated (dull silver) when new, so whatever you can use to recreate that look should be okay.Dan Peterson
Montpelier, VT
1960 Lark V-8 Convertible
Cadmium plating isn't nearly as troublesome as chrome plating but, I've found a suitable cheap alternative. I bead blast the parts, then use a rattle can spray of cold zinc, available at any hardware store. Handle the parts carefully, as the cold zinc wipes off very easily. Then I spray with a clear coat. Once that's dry it's protected from corrosion and appears much like cadmium.Brad Johnson,
'56 Sky Hawk in process
Is the cold zinc a paint color, or powdered zinc, or what exactly?Last edited by RadioRoy; 02-19-2017, 01:17 PM.RadioRoy, specializing in AM/FM conversions with auxiliary inputs for iPod/satellite/CD player. In the old car radio business since 1985.
Originally posted by RadioRoy View PostIs the cold zinc a paint color, or powdered zinc, or what exactly?
Being a CASO, I go with a simple cold zinc and a cheap clear coat. It passes muster in SDC judging.Brad Johnson,
You can burnish the cold galv spray with a green dish scrubbie scotch-pad. (not to be confused with body shop 3m scotch pads). it ill put a little shine before clearing it. It makes it look more metallic, rather than grey.Bez Auto Alchemy
