Hi,
I haven't looked yet to see if the ignition rotor is available new, but I wanted to ask to be sure before I go and buy one. The rotor that is in the distributor now is very loose. It doesn't fit the main diameter and the flat is wrong. The result is the rotor is sloppy on the diameter and also can move about 5 degrees in either direction. Is this a problem part for these cars as far as availability or quality? What should I avoid to keep from getting another rotor that is so loose? Any recommendations for brand/source appreciated.
