Cowl Moldings
  • Body / Glass: Cowl Moldings
    I'm helping a friend assemble his 1960 Hawk. I did not take it apart and he does not have the parts book. I want to install the 3 moldings that go on the top cowl panel (just below the windshield). The problem is access. One fastener cannot be accessed because the speedometer housing is in the way. Another is blocked by the glove box. There are a few that I can get to, but none are easy. Are these held in place with small nuts or are snaps employed?
    Can anyone tell me what I need to get to fasten these to the panel? Thank you.
    Don't forget to replace the seals also.
    Originally posted by truckguy View Post
    I'm helping a friend assemble his 1960 Hawk. I did not take it apart and he does not have the parts book. I want to install the 3 moldings that go on the top cowl panel (just below the windshield). The problem is access. Once fastener cannot be accessed because the speedometer housing is in the way. Another is blocked by the glove box. There are a few that I can get to, but none are easy. Are these held in place with small nuts or are snaps employed?
    Lou Van Anne
    62 Champ
    64 R2 GT Hawk
    79 Avanti II
      I think the latter model Hawk had barrel clips that snap into the hole and then the molding is pushed on. You can probably get the clips from SI. Be sure to put dum-dum around the studs before installing the molding.
      Jerry Forrester
      Forrester's Chrome
      Douglasville, Georgia
        Yes,they're called barrel clips. Clip snaps into body,then pin of moulding pushes into the clip.
        Oglesby,Il.
