I recently bought a 1960 Lark. My first Studebaker. 3 speed, V-8 259. Supposedly was barn find, purchased by the PO at an estate auction. He got it to a mechanic who went through the car and replaced item to get it running. New shocks, new exhaust, new tires, rebuilt compressor, etc. Might be a rebuilt starter?
My starter sounds like a chicken when I hit the key. I pulled the starter today. I've done some research but have a few questions.
The starter is a Delco 12v, #1107651. It has a 9 tooth pinion (the ends of the pinion teeth are worn off at a 45 degree angle). The flywheel teeth look OK. I have done some research on #1107651 and my findings are that it is for an automatic transmission. 31107650 Delco starter is referenced for the 3 speed.
So, do I have the wrong starter? If so which one should I have and where can I get one?
While I have you guys reading this, I don't see any indication that my transmission is an overdrive. At least I don't have the lever under the dash to engage it. Did they make non OD 3 speeds?
Thanks in advance.
Thanks in advance.
