Trans -adapt carbertor flange ( 1955 ,259 , 4 barrel
  • Engine: Trans -adapt carbertor flange ( 1955 ,259 , 4 barrel
    Does anybody know if the carb adapter will fit on the orignal 1955 4 barrel manifold , Summit Racing catalog lists part number TRD 2064,, summit notes that inboard small holes have to be drilled to accept a Rodchester carb... I would like to try a holley 570... Thank you for supporting studebaker Mike
    Yes, that's the one you want. It fits all of the WCFB carburetor/manifold bolt patterns.
    Note, after a few (full temp) heat cycles, It's a good idea to pull the carburetor, retighten the adapter to manifold fasteners, put it all back together. One time should do the trick.
    You may get away without doing this...just good to resqueze the new gasket after a few heat cycles.
