I've been trying to find a 56 Sky Hawk fan shroud...no luck. Would a 55 Studebaker Commander 4 door sedan fan shroud interchange? Thanks...
Studebaker Commander 4 Door Sedan Radiator Shroud
Not likely. The radiators on the two cars are mounted at different angles and the engine to radiator distance is different. You will likely need a shroud from a C or K car. This should not be hard to find as so many C/K cars are modified with different engines.RadioRoy, specializing in AM/FM conversions with auxiliary inputs for iPod/satellite/CD player. In the old car radio business since 1985.
I have the original shroud that came off my 59 Silver hawk (V8 motor). I've modified it so that you can easily remove the top half without having to do anything else. I also trimmed off a little of the part that that gets close to the engine accessories. Otherwise it's in very nice shape. Pics upon request.
Treblig
I just went out and opened the hood on my 55 commander K California built car. The shroud is not as deep and narrow probably because of the hood design. I would think that you will need a 56-61 shroud to work. Nice job on the modification.
Bob Miles
Tucson AZ
