Hello! In our 57 Golden Hawk, there is a factory oblong hole in the firewall behind the heater control valve. We don't know what it is for, and we are wondering if there is a grommet to plug it up. As it is now, when the car is driven, hot air blasts throught the hole onto the passenger's legs. During the summer months, it quickly becomes unbearable. We would rather plug it correctly than us having to rig something up (grin). Thanks for any help here!
Hole in firewall of 57 Golden Hawk
Tags: None
If you are referring to that large oblong hole in the far Rt. (passenger side) of the cowl, that would be for the heater thermostatic valve. The only 'seal' Studebaker used around that valve mounting hole was grey Mortite caulking cord. It looked similar to what you can buy at Lowes, HD, etc. https://www.amazon.com/Frost-King-B2.../dp/B000LNODSQ
IF ...you wanted to do a pro-looking job you might want to get some of this: http://upstartautoparts.com/3m-08578...FU08gQodI6wIiA
Like others have stated, a few pics. would be great!Last edited by 56Golden; 09-20-2016, 07:36 PM.
Did you not put the control valve end through this hole? Only the thermostatic part is inside, and the hoses protrude through on the engine side.Bez Auto Alchemy
Curiosity got me out to my 53 coupe which has same hole in fire wall.it sounds like the valve has been mounted in front of hole,the flange on the valve is 2 1/2x 3 3/4 and is designed to block the hole when heater hose comes through hole and thermostatic control is mounted inside the cabin. the valve is designed to be mounted from the inside i believe as it is held in place by 2 sheet metal from the engine compartment side. Luck, ,Doofus
What Bez and doofus said. But we really need pictures to understand what you are dealing with here - maybe some sort of non-OEM heater valve?
Where in North Carolina are you?Paul
Winston-Salem, NC
Check out my YouTube channel here: https://www.youtube.com/user/r1lark
Originally posted by r1lark View PostWhat Bez and doofus said. But we really need pictures to understand what you are dealing with here - maybe some sort of non-OEM heater valve?
Where in North Carolina are you?Last edited by JLau; 09-21-2016, 05:33 AM.
What you guys are saying makes sense. I am not a mechanic, I manage a classic car collection. This car was purchased prior to my coming aboard. But the tech has said that the car was a mess when he got it. The supercharger was gone, and it was decided that it would be too expensive to put one back in. Instead, the tech rebuilt what was there using the correct parts. He re-wired the entire engine compartment using 1957 technology, so it now looks like original wiring. I am having trouble with my email this morning. It is not receiving photos from my phone or other peoples' phones. I will post photos as soon as I get this straightened out.
Bez Auto Alchemy
