Hi all-
I am close to running out of valve adjustment on the Reconditioned 289 V8 I'm building. Of note is that the oil holes at the top of the rocker arms in the Left bank are almost shut by the adjusting screws, the right bank are well and truly shut. I believe that a couple are at their maximum and will not allow a 0.027 cold valve adjustment .
Now, I believe I've done my homework right-
1961 engine with number P77537 (therefore, after modified rockers and pushrod sets occurred)
All rockers show part No. 1550613- later production as per above
All Pushrods in my collection were all the same length- give or take a 'poof-teenth' - in the order of 11 5/16" long
All adjusters look to be barely one inch long= i.e. short versions as required for 15450613.
I have installed 0.015" steel shim head gaskets rather than the wafer type the heads originally had out of the '63 cruiser.
The block has been decked a minimal amount- I believe that it has never been shaved before.
The heads came off another engine-a '63 cruiser. I believe that just maybe they might have been shaved before- checked volume of one combustion chamber at approx 65cc. I imagine this might be the mail cause.
I'm wondering what more experienced fellers might suggest-
Do I pull the rockers (damn- just pulled down both head gaskets!) and shorten the adjuster screws to expedite oiling?
Ought I shim under the rocker stands to lift 'em up?
Do both the above.
Cherry picking the shortest pushrods out of my spares collection to re-install is a commonsense option but not likely to solve the problem on its own.
Steve
Do both the above.
Steve
