I have seen some past posts about these weatherstrips, (53-61 c/k). But is there a "BEST" current supplier or are they all made by one vendor. I know some of you have installed some recently. Lets hear about your experiences and recommendations please.
C/K Windshield and Back Glass Weatherstrip
Tags: None
I gotta plead ignorance here Altair, what does your tool do??? are you installing rubber first then glass? or does this get rubber to lay over body flange. I have helped install a few and when done right the glass "Rolls In" and rubber pulls in over flange. if done wrong lower rubber flange sticks straight in and glass isnt set in properly. please explain. Doofus
I have also done this job using string, by placing a string around the rubber flange held in place with dots of rubber cement and lubricated with window cleaning solution. The string is extracted as it pulls the rubber over the flange. The window goes back in in minutes.
Thanks Altair, have done the string thing but always set bottom in first with rubber over flange then pulled string up both sides then across top watching for rubber to "Roll In" over flange. always a fun job for sure! Thanks Doofus
glass install
Originally posted by altair View PostI have also done this job using string, by placing a string around the rubber flange held in place with dots of rubber cement and lubricated with window cleaning solution. The string is extracted as it pulls the rubber over the flange. The window goes back in in minutes.
Originally posted by Jeffry Cassel View PostValerie Hansen. Replacing this is a hellish experience - at best! I think the thing to do is cut those stupid flanges of the stainless trim strips. I've frustrated a body shop and 2 different car restorers! Most repo rubber just doesn't fit!
You MUST install the stainless, rubber, and glass as a unit into the car.Bez Auto Alchemy
Originally posted by rkapteyn View PostThey come all from these same place.
Valerie took over the business from Bill Fennessey (spelling?)
Wonderfull person to deal with.
Robert Kapteyn.
I also have very good luck with Studebaker Glass and Rubber. Do I have that name right? I think so. I believe they're in the Spokane, Wa. area. Nice guys.1950 Commander Land Cruiser
1951 Champion Business Coupe
1951 Commander Starlight
1952 Champion 2Dr. Sedan
1953 Champion Starlight
1953 Commander Starliner
1953 2R5
1956 Golden Hawk Jet Streak
1957 Silver Hawk
1957 3E5 Pick-Up
1959 Silver Hawk
1961 Hawk
1962 Cruiser 4 speed
1963 Daytona Convertible
1964 Daytona R2 4 speed
1965 Cruiser
1970 Avanti
