I have gone through several attempts to get the Golden Hawk running as it should including replacing the intake manifold gasket, rebuilding the carb, setting the valve lash, separating the 5 and 7 plug wires and attempting to adjust the timing various ways.
I spoke with Ingvar Vik who informed me that the procedure for checking valve timing was in the service manual. I performed the test twice with the same result each time.
Valve timing is not correct. The timing pointer was about 3/4 inch from the line at the IN.OP. on the damper. When the timing is correct the line should be directly under the pointer. So I opened it up to see if the gear was off. The pictures show what I found.
There are two "o's" stamped on the gear and as you can see the smaller one is in the wrong spot. Could someone have added the larger "O" and put it on the wrong side?
