Hi,
I'm rebuilding my differential, but ONLY replacing the seals, outer axles bearings and removing the pinion bearing and cleaning it (assuming it's good). NOT taking out the innards of the differential due to the advice against it and the amount of careful tuning to get all the tolerances right (and not having all those tools the shop manual lists!)
My plan is to drain (done), remove the axle seals (done), clean that area good with a rag stuffed in axles tube to avoid getting junk caught in the differential bearings, and then after I finish wire-brusing, finally remove the rear cover and finish mopping out the remaining sludge and grease, and checking pinion gears and such.
But my question is this; those axle tubes are filthy; but I don't see how you can really clean them without getting the "grit" and garbage inside the differential.
My plan is once I remove the cover, to flush out with about 1/2 gallon of laquer thinner, letting it run out one side into a pail, then tipping the other way (after it drys) and doing the same thing, through the other axle tube, rotating the pinion and bearings the whole time I'm flushing it. Then I'll remove the dust-cover and pinion seal, remove THAT bearing and clean it, and with differential horizontal, dump the rest of my lacquer thinner through and drain through the pinion , rotating THAT bearing good to clean it.
Finally, pack as much bearing grease as I can in them (though I'll fill it with lube once I get it on the springs and mounted on the frame again).
I couldn't find anything about how to clean a differential (mine is standard, not Twin Traction, 57 Golden Hawk) on the Forum. I would think those axle tubes should be clean if lube is supposed to work its way down and keep the outer axle bearings lubed, but they are sure 60 year gritty/grimy now, and trying to push a cloth or something with brake cleaner, etc up them will only push crap up into the only bearings on the whole car that are NOT coming out and getting replace.
Thoughts/advice?
Thanks!
OH, almost forgot. Another thing; when I removed the right-side axle bearing, I first measured depth or rarther, how far it was sticking out past 'flush' from the axle housing flange. (should match shim pack, but haven't added them up yet), ideally the tolerance will be the .006" or whatever. BUT, if it is LESS, and I have to remove a shim, how do I get that bearing 'just a bit out" and matching the shim pack again? have to 'pull the axle' with the drum again, and tap it in just slightly less (to the new shim pack thickness? I forgot to measure it before I took the backing plate off, but hopefully it was right and I'll replace the exact same shims, so SHOULD be correct, unless worn......?
Thoughts/advice?
Thanks!
