Last night I tried to remove the temp sender from my '62 289. After driving only three miles it's registering 240 degrees on the gauge but showing no signs of boiling or steam. I'm guessing it's about a 50/50 chance of being either the sender or the gauge. I thought the sender would be the easier of the two to work with. (GT Hawk dash doesn't look welcoming to take apart.)
I got a good solid grip on the sender with an open end 5/8" wrench, but couldn't turn the sender out of the block. I even tried tightening it a bit more to budge it loose, but no go.
How much torquing can that little piece of brass take without snapping apart or rounding? I don't want to make things even worse. Is there an easier way to get the sender out? Is it more accessible from underneath?
Paul
Paul
