Hello,
I have had some personal things come up that cause me to not follow up on my findings earlier. I did the following:
- Checked for bare wires, loose connections, I just installed new spark plug wires and reproduction stock wiring from Lark Works. I was hoping to find some loose wire or something, but everything checked out.
- Coated the accelerator pump with foot oil as suggested since the carburetor was recently rebuilt.
- Carburetor seems to deliver via the accelerator pump a healthy stream of gas when the foot pedal is pumped.
- Pump still delivers stream even after car has ran up to operating temperature.
The problems I still have now include:
- Car will start up instantly, but will stall for a fraction of a second before picking back up to idle. This happens with the foot completely off the accelerator pedal. Feels like something is delaying but then catches up.
- Car will steadily increase in idle speed during the first few seconds of operation, I will tap on the gas pedal to bring the idle down.
- Once the idle is down, the car tends to shudder and shake a bit (Idle RPM too low?) and tends to feel like it is going to stall out at anytime, but it doesn't.
- If I put my foot on the pedal to give it a little more gas in idle, the car will stall for a fraction of a second before responding to the change in the accelerator pedal (this is the similar issue when the car is first started).
I did notice that the linkage has a spring attached to it via a collar (please see picture), should this be set at a predetermined distance? Could this be causing the lag?
Hello,
This sounds like an issue that has been broached before, but i am not able to find it. I have a 1951 Land Cruiser with the 232 and A/T. When I start the car it idles great, with the car still in park, I will attempt to press down on the accelerator. The moment I press down on the accelerator, the car stalls out. The car will start back up with no problem, but will stall again when the gas pedal is press down. Fuel bowl on the pump seems to appear full at all times. Let me know if there is something else I can provide for assistance.
Thank you
Hello,
Thank you
