What's the difference between a 1541171 (non-floor shift car) and a 1554227 (floor shift car) clutch drum. I have them both sitting on the bench but see no difference.
Flightomatic clutch cylinder
Transmission / Overdrive: Flightomatic clutch cylinder
1936 Dictator
1950 Champion Regal 4 dr parts car
1953 Commander Regal HT
1953 2R5 Pickup
1947 M16 Truck
1960 Lark VIII Convertible
1960 Champ 5E7 step side short box
1962 Champ 7E5 no box
1962 GT Hawk
1963 Lark VI 4 dr
1963 GT Hawk R2
1964 Daytona Convertible
1964 Commander Wagonaire
“America will never be destroyed from the outside. If we falter and lose our freedoms, it will be because we destroyed ourselves.” ~ Abraham LincolnTags: None
The area where the band rides should be wider in the powershift. They used larger bands. Also, isn't one three planetary gears, and the other one four?Bez Auto Alchemy
Sorry I should have said this is the front clutch. The front band runs on the rear clutch.1936 Dictator
1953 2R5 Pickup
1947 M16 Truck
1962 GT Hawk
1963 Lark VI 4 dr
1963 GT Hawk R2
All the rear bands are the same width, the front bands are wider on the heavy duty and powershift transmissions. On those units the front drum is also wider. The wide band measures 1.93, the narrower band measures 1.63 , not a big difference. Lou Cote
Originally posted by studeski View PostWhat's the difference between a 1541171 (non-floor shift car) and a 1554227 (floor shift car) clutch drum. I have them both sitting on the bench but see no difference.
\"QUIGLEY DOWN UNDER\"
MELBOURNE.
Originally posted by HAWK64 View PostClaude, If you look closely at the inner diameter of both drums you should see a slight difference in the diameter of the angled hole through each. I believe the floor shift variety allows more pressure in behind the aluminium piston.1936 Dictator
1953 2R5 Pickup
1947 M16 Truck
1962 GT Hawk
1963 Lark VI 4 dr
1963 GT Hawk R2
All of the differences between the Standard Flight-O-Matic and the Power Shift are designed to allow it to live with the Manual 1-2 and 2-3 Shifts that are available.StudeRich
