What's the difference between a 1541171 (non-floor shift car) and a 1554227 (floor shift car) clutch drum. I have them both sitting on the bench but see no difference.
Flightomatic clutch cylinder
Transmission / Overdrive: Flightomatic clutch cylinder
Claude Chmielewski
Studeski
http://www.studeski.com
Fillmore, Wisconsin
47 M-16 Truck
53 Commander Regal HT
53 2R5
60 Lark VIII Convertible
60 5E7 Champ pickup
62 5E7 Champ no box
62 GT Hawk 4 speed
63 Lark VI parts car
63 GT Hawk R2 4 speed
64 Commander Wagonaire
64 Daytona Convertible
50 Champion Regal (parts car)
36 Dictator
36 Dictator in piecesTags: None
The area where the band rides should be wider in the powershift. They used larger bands. Also, isn't one three planetary gears, and the other one four?Bez Auto Alchemy
Sorry I should have said this is the front clutch. The front band runs on the rear clutch.sigpic
Claude Chmielewski
Studeski
Fillmore, Wisconsin
47 M-16 Truck
53 2R5
60 5E7 Champ pickup
62 5E7 Champ no box
62 GT Hawk 4 speed
36 Dictator
All the rear bands are the same width, the front bands are wider on the heavy duty and powershift transmissions. On those units the front drum is also wider. The wide band measures 1.93, the narrower band measures 1.63 , not a big difference. Lou Cote
Originally posted by studeski View PostWhat's the difference between a 1541171 (non-floor shift car) and a 1554227 (floor shift car) clutch drum. I have them both sitting on the bench but see no difference.
\"QUIGLEY DOWN UNDER\"
MELBOURNE.
Originally posted by HAWK64 View PostClaude, If you look closely at the inner diameter of both drums you should see a slight difference in the diameter of the angled hole through each. I believe the floor shift variety allows more pressure in behind the aluminium piston.sigpic
Claude Chmielewski
Studeski
Fillmore, Wisconsin
47 M-16 Truck
53 2R5
60 5E7 Champ pickup
62 5E7 Champ no box
62 GT Hawk 4 speed
36 Dictator
All of the differences between the Standard Flight-O-Matic and the Power Shift are designed to allow it to live with the Manual 1-2 and 2-3 Shifts that are available.StudeRich
