Just wondering, is anyone here familiar with the difference in grinding procedures for flat tappet versus roller lifter cams? I am talking about "straight" versus "tapered" lobe grind.
I understand: all 1950s-1960s flat tappet motors (except Buick nail heads) had tapered lobe grinds. The taper was in minutes (versus degrees); drop was measured at 3/8" width, and was usually .0005" to .003", dependent on the motor's spec. The tapered lobes mate with the slightly offset, convex lifter ends, to spin the lifters. Roller lifters are flat, are not offset, and mate to a straight ground cam.
In talking to several cam grinders, I find some do not have a clue about the above, but others pick right up on the conversation. So I believe this is a perishing skill, yet critical to differentiate. Obviously, a straight ground cam, used with convex tappets, is a disaster in short order.
If anyone is familiar with the above, do you know the spec for Stude V8s?
Thanks
Thanks
