'62-64 GT Hawk Rear Window Adjust Closed
  • Body / Glass: '62-64 GT Hawk Rear Window Adjust Closed
    The problems encountered in adjusting the GT's rear quarter windows to "lock" in the closed/up position may be a result of the misalignment of the mounting holes in the MOUNTING PLATE or the WINDOW REGULATOR or the INTERIOR BODY
    My '63 driver side adjusted, just barely, at he very extreme of the slotted mounting holes in the regulator - The passenger side would not adjust at all. The holes in the regulator had been crudely "hogged out" oversize previously. After removing the MOUNTING PLATE and REGULATOR to the work bench several positions of the regulator arm were tried to determine where the adjustment takes hold to "lock" the window in the closed/up position. The ONLY place was at the black regulator arm's most extreme "UP" position, where it pressed against the silver colored bearing support plate - It is at this position that the regulator adjustment (as installed in the car) will "LOCK", resisting pressure to partially open.
    The repair consisted of further elongating the regulator mounting holes (the ones already over size) until they allowed the regulator to be rotated far enough to "LOCK" against the bearing bracket. All work was guided by the SHOP MANUAL, Body-K Model, Rear Quarter Window, Adjustment
    The result? the window will resist forceful efforts to open the window when in the closed/up position, moving not more than 1/16 inch.
    Hope this helps what can be a very frustrating adjustment.
    Paul TK, Oceano, CA
    Good info. Do you happen to have any pictures of the work you did on the windows? I need to perform a windowectomy on my Hawk.
      Chuck,
      Sorry, I use the library internet and it is not possible (to my knowledge) to get thru' its security system to get pic's in the "bucket" system so that they can be posted to the Forum.
      However, once you get the regulator out of the car it will be fairly obvious as to what the explanation is. Also, there will be an updated (hopefully more self evident) posting as soon as I have some time.
      Go with the window adjust,
      Paul TK
        Thanks. Appreciate the info.
