by-pass oil filter
  • Engine: by-pass oil filter
    I am using a NAPA 1050 oil filter on my 259 partial flow engine. This filter is designed for by-pass systems and is supposed to restrict the flow of oil. My question is, does it restrict the flow enough on its own or is a flow restrictor fitting needed in the oil line from the engine to the filter?
    There should be a restrictor on the inlet side of the filter which if I remember correctly has around a .040 hole in it. If you have an original oil filter mount installed on your engine, it should already have the restrictor on it. Bud
      I'm replacing the original mount with a Baldwin OB1305/NAPA 4755 filter base. It requires a separate flow restrictor. It can be in the filter or the tube.
        Restrict the fitting on the incoming side of the filter, if it is not already a restricted fitting.
          Hey Old Guy some oil filters have a restriction built in to the exit or threaded hole, Champ filters for sure.check it out. luck Doofus
            The part numbers for the Studebaker V8 partial flow filter are listed below.
            The restriction is a fitting in the line, and not in the filter itself.
            It should not have a 'bypass' valve, as it is a partial flow system filter.
            Depending on the brand, it 'could' have an anti-drainback valve (which is NOT a bypass valve).
            Check your individual choice of filter to be sure, as years of consolidation of part numbers by manufacturers have muddied the waters for replacement parts.
            AC-Delco P3
            ALLIS-CHALMERS 1EK11972
            ALLIS-CHALMERS 4512207
            ALLIS-CHALMERS 4512207-4
            ALLIS-CHALMERS 45122074
            ALLIS-CHALMERS 74900600
            ALLOY ABH-50
            AUTOPAR FE20
            AUTOPAR FE63
            B&W-LATHROP P-2417
            BAKER 101254
            BAKER 737R1
            BAKER 737W1
            BAKER 9033AM1
            Baldwin B222
            Baldwin B296
            Baldwin B494
            Baldwin B50
            BIG A 92050
            Bosch 0451202001 1
            Canadian Tire 17-1722
            CARQUEST 85050
            CATERPILLAR 3I-1113
            CATERPILLAR 6663172
            CATERPILLAR 68147
            CATERPILLAR C-68147
            CENEX CO97
            Champ PB50
            Champ PH226
            CHAMPION OF412
            CHECKER 95021
            CHRYSLER 2196908
            CHRYSLER 3154364
            CHRYSLER 8990508
            CHRYSLER 925418
            CHRYSLER 928055
            CHRYSLER 936407
            CHRYSLER 991718
            CHRYSLER J0925418
            CHRYSLER J0928055
            CHRYSLER J0936407
            CHRYSLER J0991718
            CHRYSLER J3154364
            CHRYSLER J8990508
            CLARK 1752522
            CLARK 990936
            CO-OP PL-50
            COOPERS AZL057
            CROSLAND 536
            DELUXE WD-97
            Donaldson LFP550050
            Donaldson P550050
            Donaldson P550196
            Donaldson P550972
            Donaldson P559615
            DYNALIFE CN-51050
            DYNALIFE CN-7
            FACET 50
            FIAAM FT4418
            FIAT 4007348
            FIAT 4026075
            FIAT 4083490
            FIAT 4107775
            FIAT-ALLIS 74512207
            Filters Incorporated OF50
            Fleetguard LF3543
            Fleetguard LF607
            Fleetguard LF786
            FLEETRITE LFR-8607
            Fram PB50
            General Motors GM 5574639
            General Motors GM 5574641
            General Motors GM 94169779
            General Motors GM 94360419
            GONHER GP50
            GONHER GP50M
            GRAND PRIX PB50
            Group 7 L30003
            HASTINGS LF117
            HASTINGS LF198
            HASTINGS LF445
            HERCULES 208728
            HERCULES 256274
            HERCULES 256274-B
            HERCULES 286760-C
            HOBART 509021
            HUTCHEN S-3
            HYSTER 180282
            HYSTER 180320
            HYSTER 181769
            HYSTER 3000043
            Isuzu 8-94169-779-2
            Isuzu 8-94360-419-0
            Isuzu 8-94360-419-1
            ITM 11-16305
            JIFFY LUBE HL50
            John Deere HMF600L04340
            KNECHT FO-356
            KNECHT FO-370
            KRALINATOR L23B
            KRALINATOR L30
            LEE LF-3
            LPM 1350-5050
            LUBER-FINER LFP2270
            LUBER-FINER LFP3
            LUBER-FINER PB50
            Lucas Girling F5541
            Lucas Girling F646
            Mann Filter WP9.31/1O
            Mann Filter WP931
            MARATHON PB50
            MARATHON-LETOURNEAU PB50
            MASSEY-FERGUSON 1032015-M91
            MASSEY-FERGUSON 1900377-M91
            Master Parts PB-50
            MIGHTY L20024
            MIGHTY L30003
            MIGHTY PB50
            Mitsubishi J0925418
            Mitsubishi J0928055
            Mitsubishi J0936407
            Mitsubishi J0991718
            Mitsubishi J3154364
            Mitsubishi J8990508
            MOBIL L30003
            MOPAR L-4
            MOTORCRAFT FL 3
            NAPA 1050
            NELSON 85006-A
            NELSON B-335-SCR
            PHILLIPS 66 P3
            PHILLIPS 66 WO1050
            PROMATCH 68147
            Purolator L10019
            Purolator L30003
            Purolator L35492
            Quaker State L30003
            Quaker State PO-116
            ROL-PAK FPB-50-BP
            ROL-PAK FPBQ-50-BP
            RYDER 990936
            SHELL L30003
            STP PB50
            TELEDYNE F-600L-4340
            TENNANT 53055-2
            UNITED (ENGINE LIFE) U4L
            UNOCAL OF1050
            WALMI WS-50
            WARNER PB50
            WAUKESHA 199269
            WGB S-87-CP
            WHITE 1-4397-A
            WHITE 104397-A
            WHITE 600136-AA
            WHITE 60514-AS
            WHITE 605814-ASA
            Wix 51050
              I stated NAPA 1050 in my original post and it is on your list Jeff. It has no anti-drainback valve. It is designed for by-pass or partial flow systems. My question is whether or not this particular filter restricts the flow enough. The engine came with a brass fitting that screws into the inner front side of the driver's side head (the outlet) that has a small opening or restriction. It also came with a NAPA 1050. So again, my question is whether or not the restricted flow of a 1050 is sufficient on its own for a Studebaker 259 V8?
                Is the NAPA 1050 a cartridge filter, or a spin-on? The cartridge filters (replaceable element that goes in a canister) require a restrictor fitting on the inlet (pressure) side. The hole is .050" IIRC. The spin-on bypass filters, and Studebaker did use them, usually had the restrictor built into the filter itself, visible as a small hole in the bulkhead beyond the end of the spin-on thread well. You didn't need a restrictor in the pressure line, in that case.
                  The 1050 is a spin on. Thanks for the info. I have contacted NAPA for the specs and when they get back to me I will post the results here.
                    I waited three days and NAPA finally just sent me a phone number to call. I don't have time for that right now. I'm going with gordr's advice (see above).
                      NAPA buys all of it's filters from Wix, so they would just refer you over there...
                      1050 NAPA - 51050 Wix
                      NAPA Spec: http://www.nfhconnect.com/Lookup/Par...0704&Brand=NAP
                      Product Specifications
                      Part Number: 1050
                      UPC Number: 765809135840
                      Style: Spin-On Lube Filter
                      Service: Lube
                      Type: By-Pass
                      Media: Enhanced Cellulose
                      Height: 5.178(132)*
                      Outer Diameter Top: 3.66(93)*
                      Outer Diameter Bottom: Closed:
                      Thread Size: 5/8-18
                      By-Pass Valve Setting-PSI: None
                      Burst Pressure-PSI: 380
                      Max Flow Rate: 1-3 GPM
                      Nominal Micron Rating: 10
                      Operating Temp. (min): 0
                      Operating Temp. (max): 0
                      Capacity: 0
                      Filter Area: 0
                      ( )* denotes metric
                      Gasket Diameters
                      No Gaskets found
                      Part Number: 1050
                      Wix Spec
                      Part Number: 51050
                      UPC Number: 765809510500
                      Service: Lube
                      Type: By-Pass
                      Height: 5.178(132)*
                      Thread Size: 5/8-18
                      Note: By-Pass Style Filter - Filters Out Contaminants To Extend Oil Drain Intervals. If Shorter Version Required, Use &&51051&& or &&51320&&:
                      Capacity: 0
                      Filter Area: 0
                      ( )* denotes metric
                      Gasket Diameters
                      Attached 2.834 (72)* 2.462 (63)* 0.200 (5)*
                        Great! No mention of the restrictor or it's size but it clearly is there as you can see.
                          The Wix 51050 and Fram PB50 filter have a restrictor built into the outlet side of the filter, but I still recommend using the restrictor that Studebaker originally specified on the inlet side of the filter. You could have a low oil pressure issue without the restrictor on the inlet side, especially when the oil is hot as by pass filters dump the filtered oil directly back to the oil pan. Bud
                            Technically, as long as the filter can handle the system pressure, it matters not where the restrictor is.
                            Studebaker made the restrictor the last item in line, as it would only see filtered oil.
                            The oil filter restrictor is post media, so it works the same way.
                            On a bypass system, no matter where the restrictor is, or even if the filter was 100% plugged, the engine will not see a low oil pressure due to the bypass filter setup.
                              If a by pass filter is plugged there won't be an oil pressure drop as no oil is flowing through it. A new filter has little restriction which allows more oil to flow through it which will drop the oil pressure. Keep in mind with a by pass filter, part of the oil that is meant to lube internal engine parts is being diverted through what is essentially a leak in the lube system which will drop the oil pressure. The amount of pressure drop depends on a restriction to oil flow through the filter. Studebaker specified the installation of a restrictor on the by pass filters and I recommend using one of the correct size to maintain good oil pressure. Bud
