hi, doing a complete frame off with my 57 Golden Hawk.
I just got a new front-crossmember installed (old one cracked/welded...shot) and NOS control arms, king-pins, etc etc.. I have read that the adjustments for the front end should NOT be done unless the car is fully loaded (engine, body....).
BUT, it is SO convenient access right now obviously, and I'd like to do as much as possible before the engine goes back in, and (someday) when the body gets completed, and goes back on.
So, I'm wondering if a guy should adjust per the Manual 'as if' the car WERE loaded, and then know fine-tuning will required later 'under load'....? (and correspondingly don't pin nuts or Loctite threads! :-)
OR, is there a 'known bias" one way or another, or "rough specs" to shoot for when you are working with an unloaded frame only, so it will be very close once the weight of engine and body is finally added?
One in particular is the upper control shaft; piece of cake to install that now, without coil springs in place; a real bugger to get at later! Hope I guess right initially now and don't have to "flip" that little dog-bone 'inner shaft' it pivots on later!! (have heard it generally has the 'offset' holes towards the engine... but was made to flip for adjustment if needed. ugh! Hope NOT needed!)
Also, any 'tricks' or warnings about starting NOS trunion nuts in NOS control arms, that come UNTHREADED? I'm sure the factory had a jig to keep them straight ... I'm concerned about keeping the nuts (for king pins, top and bottom pivots) perpendicular to the control arms when starting them, cutting new threads.... Maybe they are kind of self-guiding (with the inner threaded pieces in place? ) but if they get cockeyed, I know those INNER threads for the king pin 'pins' will bind and control arms will not move up and down freely.
Thanks!
Barry
Thanks!
Barry
