Hi folks, been gathering info about my next project, have some questions. I have a Lark convertible I'd like to rejuvenate, and I'm in the process of getting the 259 V8 from member treblig- it came from his '59 silverhawk. I plan on using a 2004r overdrive, & the engine WAS tied to an automatic. Can I use the Hawk frame mounts up front, and adapt some GM transmission crossmember to support the rear of this package? Or do I need Lark V8 frame mounts? I've read conflicting info that says I can swap my present 6 frame mounts from side to side to fit the V8. Is that not correct? I understand that the Studebaker style bellhousing mounts won't be used. Also, can I use some or all of the throttle linkage? I understand many of the differences between 6 cylinder and V8 cars. Does anyone have experience lowering a V8 lark; I know I need V8 springs, but to me the car would look & handle better lowered about 2 inches. So to get there, how much should I cut the V8 springs? My shopping list is long enough that I'm considering finding a parts car to do this swap. I want power steering, A/C, Turner discs and anti sway bars & I know I'll need a different rear axle. I appreciate the knowledge and willingness to share of all on this board. Thank You,
Steve Mohr
Steve Mohr
