After a search on this forum, I could not find the answer to my question. Before I get into that, could someone pls tell me how to do a sort on this forum? Best I could do was a search for "283 distributor" (nothing), "distributor setup", "distributor" and then "ignition". I read all the posts after searching for each but had to wade through several hundred unrelated posts and never found anything close. There must be a way to sort but I have been unable to find it. A simple search will just give you every post with your key word in it. Even if there was a way to sort just for the "Prefix" would really help. For example the "ignition" prefix search would have cut the # of post down considerably except it again, looked for the key word, not the Prefix.
Problem: I have a rebuilt 66 Daytona 283. The manual gives two ways to set up the distributor on a disturbed engine, both start by getting to #1 TDC. The first method is the way I have always gotten to TDC - let the compression blow your finger out. However, on this engine, with PS, you can just barely, after a 1/2 hour struggle, get the plug in, just to describe how hard the hole is to get to. To actually get the meat of your finger on the hole enough to seal it is impossible. I have gone from the bottom up, top down, and sideways. Best I could do was get tip in the hole but my finger nail prevents a good seal.
The second method is to crank while watching the intake rocker arm and when the mark comes up while the rocker has just closed, that should be compression and you just set the mark on TDC. Okay, there are of course two rockers and I have torn the manual apart trying to find some indication of which one it is. I had a machine shop redo the heads and put it all together last year, so I do not remember which valve was smaller (I presume that would be the intake). Do any of you know if the intake is the front rocker or is it the back one? I guessed and set the distributor in place and the engine backfires violently so obviously I am 180 out.
I'd take out the plug and try to jam something into the hole, like an eraser that has been carved down to fit but damn, that just seems like a lot of work that might prove futile - just getting one finger in there is tough and the two required to hold something, well......
The rocker arm method would be the easiest to do at this point so I sure hope someone knows which rocker arm is the intake.
