62 GT motor mounts
Make a U shape out of some 2x4's with an inside width to match the oil pan and a length to allow you floor jack to fit under it. Brace the U so it won't spread apart and place it up against the pan flange area and jack the motor up. That would be what I would try anyway.
Ken
Originally posted by jd-stude View PostMake a U shape out of some 2x4's with an inside width to match the oil pan and a length to allow you floor jack to fit under it. Brace the U so it won't spread apart and place it up against the pan flange area and jack the motor up. That would be what I would try anyway.
KenI'd rather be driving my Studebaker!
Originally posted by stude dude View Post32 Ford mounts...? What do they look like?
Chris.
I'm doing the exact same thing on my '62 Hawk this weekend.
Clark posted a description of the process on http://studeblogger.blogspot.com/201...1_archive.html.
One difference on our Hawks is the heater/Climatizer hoses pass in front of the right rear mount bolts, if so equipped.
Making a brace to protect the pan is a good idea. As everyone says, DON"T FORGET THE SPACER ON THE LEFT REAR MOUNT!
Maybe I'll post here how it went when I'm done. Though I suspect mission creep might force another thread altogether. First hour was removing crud older than me.Andy
62 GT
What a can of worms! I made a U shaped lifting bracket out of 2x4s and plywood. Lifted the engine slowly and removed the old motor mount from the drivers side. As I'm using 32 Ford motor mounts I have to modify the lower bracket so it has to be removed. If I could find the design engineer who put the bolts for the lower bracket INSIDE the hollow cross member I'd slap him upside the head. Why do so many engineers forget about the fact that cars have to be worked on?I'd rather be driving my Studebaker!
About ready to start round 2 of my fight with the lower motor mount bracket bolts. If I could just get a wrench or socket on the bolt head inside the hollow cross member it would be a piece of cake. I might have to make a trip to Sears to see if they have an extra long 9/16 box wrench. If not I'm gonna haft ta get something welded up that will reach up in there. But on the bright side look at all the fun I'm having.I'd rather be driving my Studebaker!
Originally posted by wlfrench View PostWhat a can of worms! I made a U shaped lifting bracket out of 2x4s and plywood. Lifted the engine slowly and removed the old motor mount from the drivers side. As I'm using 32 Ford motor mounts I have to modify the lower bracket so it has to be removed. If I could find the design engineer who put the bolts for the lower bracket INSIDE the hollow cross member I'd slap him upside the head. Why do so many engineers forget about the fact that cars have to be worked on?
Originally posted by wlfrench View PostIf I could find the design engineer who put the bolts for the lower bracket INSIDE the hollow cross member I'd slap him upside the head. Why do so many engineers forget about the fact that cars have to be worked on?
Poll Question: Who has broken a newly replaced engine mount after removing the original 50+ year original ?? I've never heard of it..... I'm curious. If I were breaking mounts, I'd be careful about modifying the original bracket w/o some buttressing.....
Years ago I had a Hawk (loved that car) that had mount problems. One day I decided to solve my mount problem and proceeded to change out the bonded mount with a bolt through mount I had purchased from the local Ford dealer. I started the procedure by placing the car on stands, then loosening and raising the engine. After a couple of hours of work trying to remove those four bracket bolts (without removing the front suspention) I decided that the bonded mounts were not the problem but could be traced to my driving habits. So I went down to the parts store, bought a new bonded Studebaker mount and installed it, took my Ford parts back to the Ford dealer. With the engine out of the car or the front suspention removed, the mount modification would have been rather simple. In all the years I owned the car I only replaced that left mount once. And by changing my driving habits I probably also saved a lot of money on u-joints, transmission parts, and many other items too numerous to mention. Sure wish I had that car back!
Dave.
It took a while, but I installed new mounts this weekend on my '62 Hawk.
Lacking a proper lift/hoist, I used the technique outlined by Clark (as related to him by Gord). The only difference was that I installed the front mounts first.
If Cllimatizer equipped, you will have to disconnect the large hose from the lower duct. If your heater hosed have some slack, you can move them enough to get to the mount bolts on the side of the case. It ain't easy. but you can reach them through the fender well. If the front wheel is removed, all the easier.
The nut size on my rear mounts was 5/8" not 9/16". On the rears (especially the right side) you should be able to get a wrench in that crossmember. If you don't have clearance to remove the nut, you will once you raise it.
Slow and steady wins the race. A 9" x 12" piece of plywood fits the transmission pan perfectly, and I suffered no dents mostly because I was extreeeeeemely gentle and slow with raising and lowering. In doing so, nothing shifted much and everything lined back up just right when replaced.
I only encountered one issue - the threads on the rear mount base studs are finer (7/16" - 20) than those they replaced so new washers/nuts were required.
New and old front mounts:Andy
62 GT
