I just purchased a new "Legends" Group 24 battery from NAPA. I also purchased a "Willard" decal from SI, all for my 62 GT Hawk. What is the best way to prep the side of the battery so the decal will stick? Once the decal is on, can I spray the side of the battery with a clear coat to protect the decal. Just trying to look authentic!
New Battery
Tags: None
Once you strip off the old decals I would clean it off with a 3M adhesive remover and, once you're sure it's clean, wipe again with Prep-sol or Final-clean. New decals should then be next to impossible to remove.Brad Johnson,
'56 Sky Hawk in process
I have had problems with the decals coming off had three different ones last one did not want to come off the backing. Would like to find a stencil ib order to paint directly on the battery. On removing the id from battery I think that would void the warranty. For the top of my battery used some caps attached to self sticking foam rubber
Originally posted by acolds View PostI have had problems with the decals coming off had three different ones last one did not want to come off the backing. Would like to find a stencil ib order to paint directly on the battery. On removing the id from battery I think that would void the warranty. For the top of my battery used some caps attached to self sticking foam rubber!! Where did you source the caps from?
Paul
Winston-Salem, NC
The caps I used were from Dr Pepper the fine print on them has never been caught by anyone at event I tell anyone that asks to look and read the fine print. If you want a different color or style just shop your local soft drink store buy a six pack and save the caps
