Can any one tell me what engine this is it came out of a 1947 m-16 engine number on block is 3m38915. Thanks
1947 Studebaker dump truck
I believe the number you gave above would be correct. Parts are available from several sources. Go to your browser and type in Studebaker Vendors.
I know that Studebaker International has many engine rebuilding parts for that engine. I believe they have full rebuilding kits. The only thing you will need to determine is if the block needs to be bored. This will determine what sized pistons you need. Hopefully the crank and camshaft are reusable.
One other place you can check to determine which engine you have is to go to the SDC website and find the link to engine number ranges for various vehicles. That should give you a good idea of which engine is in your vehicle.
Others may pop up here who can give you more specific information as well.Ed Sallia
Dundee, OR
Sol Lucet Omnibus
