My friend has a 1953 Starliner V8 with an overdrive 3 speed manual transmission. He was told the unit has an oil fill, maybe two oil fills. We can't find them. Any help would be appreciated.
Does a 53 overdrive unit have an oil fill?
Two oil fill points, one in the top right side and one at the top right of the overdrive unit. Both are 1/2 NPT square head pipe plugs. I have found the best way to fill them both is with a big horse syringe with a rubber tube about a foot long from under the car. Others may have a better method.
jg; it is important to fill the Overdrive case FIRST, because there is no vent on it, and the main case will not entirely transfer and level into it, even though they are connected. That is because it will be air locked![:0]
Leave both plugs out until you wait for them to drip down and level, with the car LEVEL, then re-check that both are FULL before replacing the plugs.
We had a forum member's T-86 Overdrive self destruct because he did not know either of these important tips.
Studebakers Northwest
Ferndale, WAStudeRich
The fills are easy to find. They're the square plugs up on the side of the tranny and OD section. The lower square plugs are for draining the oil.Welcome aboard, BTW!
Miscreant adrift in
the BerStuda Triangle
