I tried starting my rebuilt '37 President engine recently. Apparently the machine shop installed the oil pump 180 degrees out and that makes the distributor 180 out also because it only goes in one way. So the pan has to come off because on President engines the oil pump is in the pan, not external like the Dictator. To make sure there were no leaks, the shop put glue (looks like yellow 3M weatherstrip adhesive) to both sides of the pan gasket. This stuff is just not letting loose. I won't just pry away at the pan for fear of damaging it.
When questioned, the shop said they use a razor knife or sharp putty knife to cut through the glue and gasket. I have done as much of that as I can, but now that the engine is back in the chassis there are all kinds of things in the way (Steering box, exhaust system, flywheel, front motor mount, etc). I've tried squirting 3M adhesive remover in where I have been able to get a razor knife with no effect. Does anyone have a suggestion for how I might get this pan off short of pulling the engine back out so I have more access? I'm fairly well pissed about this. I've already ruined the engine paint job. If the shop was closer than almost 1000 miles away (one-way) I'd pull it and they would have it back. I'm $10,000 into it and it's not right. St Louis is less than 160 days away and this is a major roadblock. Thanks. Tom
