when i purchased the late Tom Elliott's 51, i was told it would need valve guides/seats work soon. driven for two years, it smoked a little (white smoke). yesterday i took her out to get some "non-crap" gas. as soon as got on the highway at speed (50ish), it started smoking bad with a oil smell as i turned around and parked her in the cave.
i last changed the oil in September 14 with 30W Rotella and added "Bar's Engine Repair": http://www.autozone.com/fuel-and-eng...air/94559_0_0/ to see what it would do. my oil pressure actually went up a bit after driving awhile, but the smoke was about the same as before (a little).
compression test shows 114 low and 122 high. i haven't done a vacuum leakdown test yet. i've lost about a pint of oil since Sept but it does leak about the size of a coffee saucer plate amount after a drive.
i've read the shop manual and see the seats are part of the engine and appears to me machined out. i don't have the equipment nor have worked in a flathead before
. no problem pulling a OHV head and taking it to a machine shop.
so, what to do? idk of any local shops that work on these, but really haven't looked much in the past. another problem is $$$ due to the ex.
if $ was no object, i'd think about a Studebaker V8, but i'm sure i'd have to at least replace the DG150 auto trans if not more of the drivetrain.
thanks for "listening"...
EDIT: no antifreeze in the oil or vice-versa...
