Anyone know of a stronger sway bar that will fit the 50 champion? I am looking to reduce the roll on corners as much as possible. I had thought of going to an older wrecking yard and see if I could find something that could be made to work. Also what would be the effect of installing stiffer springs? I have a pair of front coils from a 98 GMC Sonoma that will fit but are quite a bit stronger. It's not difficult to swap the front springs so I am thinking about trying this. Just wondering if there are any problems with this type of switch. Thanks
50 Champion sway bar
Frame / Springs: 50 Champion sway bar
Barn Find
1950 Champion
Before I started
Jim Berry
Midlothian, TXTags: None
Originally posted by doubledaddy View PostAnyone know of a stronger sway bar that will fit the 50 champion? I am looking to reduce the roll on corners as much as possible. I had thought of going to an older wrecking yard and see if I could find something that could be made to work. Also what would be the effect of installing stiffer springs? I have a pair of front coils from a 98 GMC Sonoma that will fit but are quite a bit stronger. It's not difficult to swap the front springs so I am thinking about trying this. Just wondering if there are any problems with this type of switch. ThanksBill Jarvis
