crankshaft I.D.
  • Engine: crankshaft I.D.
    I'm tearing down an engine that started life in a 60 Lark, but a lot has been done to it, so I need to properly identify it's parts. The crankshaft is a 259 crank, casting number 536452. What I need to know is the part number for this crank. How or where do you measure the difference between the "long nose" & "short nose" cranks? Does the gear on the front of the crank need to be removed for measuring? I wouldn't think so but want to be sure.
    60 Lark convertible V-8 auto
    61 Champ 1/2 ton 4 speed
    62 Champ 3/4 ton auto
    63 G.T. Hawk R-2,4 speed
    63 Avanti (2) R-1 auto
    64 Zip Van
    66 Cruiser V-8 auto
    Hello Warren. I measured from behind the thrust plate to the crank snout. Short 2.863, long3.467. this isnt exact as i am measuring at a slight angle. Good Luck Doofus
      Thanks! That makes mine a short nose so the part# is 536454. It should be part of the 60 Lark block.
      64 Zip Van
      66 Cruiser V-8 auto
