I need some help diagnosing and correcting the excessive interior heat on my '62 Cruiser. It recently went through a complete restoration. It is a 100% stock, numbers matching car. The car runs and idles great. It does not overheat. The temperature gauge usually registers in the middle or slightly right past the middle. I have not had any overheating issues. I believe it has a new heater box under the dash from SI with all new hoses. The problem is I am getting a steady stream of hot air while cruising down the road. I have the heat knob pushed all the way in to the off position. Fortunately it is getting a little cooler out now, but during the summer or next year at the meet in St. Louis it is likely to be unbearable. Any suggestions?
Thank you,
Ben Silver, South Bend, IN
'62 Cruiser...so much fun!
Thank you,
