Bought a 289 LS Packard engine awile back for a project. Has none of the supercharger stuff but will run it as base 289. It has remains of decal Super Packard 289 that looks kinda kool.Are these decals still available? I think it would project a different look when the hood is popped.Thanks
valve cover decals for packard hawk engine
It seems that you have not gotten a Studebaker International Parts Catalog yet. The Decals (801655) are on Pg. 9 in the Paper Catalog & possibly similar in the on line version.
I can totally imagine what the Car Show comments are going to be!
"That thing LIES, that's no Packard Engine!"
The truth be told, it IS a Packard Engine.
(1) By virtue of the fact it was made by the Studebaker Packard Corp.
(2) The Car and Engine are labeled as "PACKARD"
(3) The Engine is I.D.'d as an "L" = Packard, as is the Car.
(4) Sure it is not the traditional Detroit Packard Corp. built, Packard designed Engine, but it does not matter, the Studebaker 289 Engine when installed in a Packard becomes a Packard for the above reasons.
Debate over!Last edited by StudeRich; 09-30-2014, 02:03 PM.StudeRich
Originally posted by Neil View PostBought a 289 LS Packard engine awile back for a project. Has none of the supercharger stuff but will run it as base 289. It has remains of decal Super Packard 289 that looks kinda kool.Are these decals still available? I think it would project a different look when the hood is popped.Thanks
Originally posted by acolds View PostThe corporation that made all Packard V8 was Studebaker Packard corp the 55 56 were made in Michigan 57 58 were made in Indiana . When registered they were registered as Packards thus they are Packards
Thanks Guys for the replys . StudeRich,no I don't have an SI cataloge,so I will call about one. I know the base HP rating with 7.5 compression is 210 with 4 barrel and thick head gaskets like the 56 289 Prez and Skyhawk. I plan on using thin steel gaskets,R-1 clone cam,heads I just got with R-3 intake-exaust valves,and have not ruled out R-3headers.What kind of horsepower increase can I expect with these type of engine mods ? Thanks Again,NeilNEIL G.
Neil; the big advantage in the R1 Engine which you are trying to clone is the Flat Top Pistons giving 10.25 to 1 Comp. and a lot more H.P.
So it sounds like you are using the stock 289 Dished Pistons which will net about 8.5 to 1 with 1557570 '63-'64 Std. Lark/Hawk/Avanti R1 Heads, so a guess would be about 230 H.P.
It sounds like you could be overdoing the Heads, R3 Exhausts will do nothing, and R3 Intakes will not do much without ported and matched Intake Ports, Combustion Chambers and Intake Manifold to take advantage of the R1/R2 or R2Plus Cam.
The R3 Headers will give you bragging rights and look cool with very little gain, but WILL need to have the casting "slag" cleaned out.StudeRich
StudeRich,thanks for the information. I figgerd there was more to it than just add a part, add this part,add another part an ya got a road burning non supercharged stude V-8.Maybe I"ll just settle for a 2 in .duel exaust an turbo flow mufflers.Thanks.NeilNEIL G.
Off topic....but wouldn't the Packard Hawk really have been something if S-P used up the rather large stock of Packard 352-374 CI engines that they had on hand in '57-'58 for that model....WOW!...a Packard Hawk with a 'real' Packard engine!
Originally posted by SN-60 View PostOff topic....but wouldn't the Packard Hawk really have been something if S-P used up the rather large stock of Packard 352-374 CI engines that they had on hand in '57-'58 for that model....WOW!...a Packard Hawk with a 'real' Packard engine!Bez Auto Alchemy
