I have a 55 coupe that was converted by the prior owner to a 62 v8 three speed overdrive. There is a pad on the bell crank that is supposed to hit the od kickdown switch on the firewall. When I push the gas pedal to the floor the pad is still at least an inch away from the switch and it has been adjusted all the way out. Is it possible the bell crank has been bent or is there some other adjustment that has to be made. Thanks in advance for any suggestions.
Lee
Lee
