I assume this is needed for lubrication of some key area as the manual is very specific about making sure it points toward the front. I can order new cam bearings, but does any one know which manufacturer would be correct?
SI Front Cam bearing does not have oil groove
Since the grove is to provide sufficient oil to the thrust plate, the non-grooved bearing will likely cause the motor to run at a little higher oil pressure, but at cost of reduced lube to the thrust plate.
No matter where replacement parts are from, they should have the same physical characteristics as those they replace, or someone should be able to provide a satisfactory explanation as to why the difference is OK. Haven't heard that yet here.
Last set of cam bearings I installed in a 289, the rear one's outer shell distorted slightly, probably due to being thinner or weaker. So it took an hour or so to hand ream the inner surface to fit the cam. Some things you can overcome easily, and some not.
The vendor stude4x4 on ebay is selling dura-bond bearings. From the picture, it looks like the front bearing does have the oil groove. I sent a question to him to confirm.78 Avanti RQB 2792
64 Avanti R1 R5408
63 Avanti R1 R4551
63 Avanti R1 R2281
62 GT Hawk V15949
56 GH 6032504
56 GH 6032588
55 Speedster 7160047
55 Speedster 7165279
From the recent post regarding engine parts from SI and questionable quality and or country of origin. It might be prudent to seek a vendor that specializes in engine parts and or those that have first hand experience using them.
QUOTE=64studeavanti;857550]I assume this is needed for lubrication of some key area as the manual is very specific about making sure it points toward the front. I can order new cam bearings, but does any one know which manufacturer would be correct?[/QUOTE]
53 2R6 289 5SpdOD (driver)
57 SH (project)
60 Lark VIII 2dr sd (driver)
IMHO they specialize in being able to keep us supplied with many reproduction goodies that we would not otherwise have. However to say they specialize in engines would be wrong. Call Fairborn or STUDEBAKER parts.com. I'm sure they're may be others, these are some I have personal experience with. Returns and questions are treated FIRST RATE with both of these establishments.
Originally posted by 64studeavanti View PostOne would think that SI, as the largest provider of Studebaker parts, would be one of those vendors.
57 SH (project)
Originally posted by 64studeavanti View PostI assume this is needed for lubrication of some key area as the manual is very specific about making sure it points toward the front. I can order new cam bearings, but does any one know which manufacturer would be correct?
I have the correct cam bearings for your engine.
BoBo
Well...I don't have a dog in this hunt...but what's wrong with picking up the phone and discussing this with SI? Could be that one bearing got by "Quality Control" and was shipped without the oil groove. With all the product handled, I'd be amazed if SI had enough employees and time to open every package and personally inspect every component. After all, they are the supplier, not the manufacturer. It could be that they have an entire shipment of defective bearings and could be unaware of it until someone points it out. Before jumping on the forum and broadcasting it...call them up.
I don't mean to make this a confrontational post, but SI needs to be informed about the potential problem, and be given a chance to correct it. After all, they are a valuable resource to our efforts and, although a business... a partner as well.John Clary
I plan on calling SI in the morning. The bad part of all this is that the machine shop already installed them and I have the crank and pistons installed. Now I must take it all apart and haul it back to the machine shop when I get the correct bearing. bummer!78 Avanti RQB 2792
64 Avanti R1 R5408
63 Avanti R1 R4551
63 Avanti R1 R2281
62 GT Hawk V15949
56 GH 6032504
56 GH 6032588
Originally posted by 64studeavanti View PostI plan on calling SI in the morning. The bad part of all this is that the machine shop already installed them and I have the crank and pistons installed. Now I must take it all apart and haul it back to the machine shop when I get the correct bearing. bummer!
Thought about that. If you can scrape a bearing, why not cut a groove. In any case I don't have much to lose. If I don't like the looks of it, I just get another bearing set.78 Avanti RQB 2792
64 Avanti R1 R5408
63 Avanti R1 R4551
63 Avanti R1 R2281
62 GT Hawk V15949
56 GH 6032504
56 GH 6032588
