Good Morning
My 1964 Wagonaire with a 289 has an exhaust leak coming from a small pin hole on the heat riser valve.
What does the valve do, and can the small hole be fixed with J-B Weld? The hole is a perfect circle and 3/32 in diameter. How do I know if the valve is working, I can more the lever and the spring looks ok.
Thanks for any answers. Steve from WI.
