have 1950 starlight champ. OD does not work. Relay bad. would like modify system such
that I could install switch on shifter and select OD when I want to(on or off). can I bypass all
the electrics and merely connect solenoid to the new switch and switch to hot lead.?? functions
by merely letting up on gas(any gear), toggle switch to force solenoid and be on my way. would
I have to go through a relay(or a solenoid) as I would want to go to the IGN lead so this thing
is not on all the time??? would fuse it of course. would appreciate ideas as I have feeling other
electrical parts of OD may be questionable. Kickdown is good though. I remember doing this with
my Austin Healeys "back in the day" and I liked the control ....
